2014-04-06 02:51 »
Experiencing problems with the Web site? Bugs? Errors? Need support?
Report them in here.
2014-04-09 09:54 »
@MasterOne,
Your new shiney avatar is broken in techtalk.cc Web site.
The fault is at our end and we are working on a fix.
2014-04-09 10:27 »
The avatar problem has been solved.
2014-04-09 13:09 »
We are in the process of updating our servers and tweaking some errors in user and forum permissions. The work will go on for about 4 hours from the date and time of this post. During this time, you might experience some disturbance.
2014-04-09 17:28 »
The weird permission issues have most likely been solved but please do report them in case you get "access is denied" or odd errors.
2014-04-16 16:54 »
Where is the search function?
Here it is:
http://www.google.com/search?q=site:techtalk.cc <search word>
:ugeek:
2014-05-12 02:55 »
Due to our special setup running the same phpBB on two domains and one database, there is a permission issue with the user avatars which cannot be fixed.
If you try to change your avatar and you cannot do it, please make a post in this support section and we will help you out. :!:
2014-05-14 02:25 »
I am I using the correct youtube embed option?
Let me test:
[HTTPSutubebyurl]https://www.youtube.com/watch?v=XgfWY8Iz91s[/HTTPSutubebyurl]
[youtubebyvideoid]https://www.youtube.com/watch?v=XgfWY8Iz91s[/youtubebyvideoid]
2014-05-14 02:27 »
Ok, so the best option seems to be to strip the 's' out of https and use the youtubebyurl?
2014-05-14 14:24 »
It seems that [HTTPSutubebyurl] and [youtubebyurl] doesn't work properly. They will be removed.
Please use the [youtubebyvideoid] instead from now on.
Bear in mind that it automatically converts to httpS and uses https://s.ytimg.com/... ::thumbup::
